Any Idea what this is?
i find all kinds of plugs and stuff under my hood that i dont know what they do. yesterday while snooping around i found a switch that manually turns the fans on, which i though was cool, but not quite sure of the purpose of it.
Saxapeel,
Not sure if you were trying to be funny but I almost spewed beer when I read your post. Thanks!
Where is that switch? I'd like to know if it is on my 89 S4. Sorry to hear you are selling your Shark? Are you upgrading or moving on to other interests?
Good luck,
Tim
Good luck,
Tim
as jim puts it, im trading it in to buy an "appliance." something with good gas mileage that will take me to school/safeway and back. i found the switch on the passenger side: here is where it lays
this is what it looks like when i press it
i was sorta trying to be funny. but at the same time, im serious, there are like a million things not plugged in up there and i wonder if they are supposed to be.
Sax,
You are kind of right, kind of wrong in your naming of the switch. That switch isn't supposed to be laying off to the side. It should be mounted just aft of the cross bar attachment.
This is the engine hood switch. It is used for the burglar alarm. Also, the cooling fans will run after the engine is turned off when if the engine is hot. The purpose it to shut off the fans when the hood is open and the engine isn't running (Ignition in the off position or key removed). It is for safety.
Yep, that hood switch controls several things:
Fan cutoff when hood open for safety
Alarm trigger if hood opened
Under hood light on if headlight switch turned on.
Supposed to be mounted where the hood will contact when closed.
I have heard of this low octane wiring business... anyone know where it's supposed to be?
Saxapeel,
Coffee spewing at work when I saw the photos of the "mystery fan switch."
I knew something must be awry.....never heard of such a "feature".
Thankfully, JayC67 posted a photo of its proper location and details of its function...
Best,
Tim
Best,
Tim
