S4 fan speed modulation
Never used anything but the original wetter stuff. I am digging around the PET CD to see if there is more info on upgraded cooling systems. Also curious mainly, no real problems.
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Garth S
"BTW, anybody here ever try waterwetter of the NAPA brand "enginekool"?"
No, - Does it improve the taste of straight anti-freeze?
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
BTW, Jim at INTL says the 87 to 93 fan controller modules are all the same....ie no upgrade.......
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Originally Posted by Gretch
Cool, (pun intended) where are the controllers located, is an upgrade straight forward?
It's the controller that is mounted in the nose, I believe. I looked around a little, but have had no luck finding any info regarding upgrade.
I plan on bypassing / redesigning.
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Old & New
Hi Gretch,
Looking at the specifications that jayC67 posted above, I think it is an elegant solution as designed.........
Let me know what you do.........oh fellow "blown-sharkster"......
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
One of the changes for the 1992 928 GTS
![](http://members.rennlist.com/t_max/images/Final_Stage01B.JPG)
![](http://members.rennlist.com/t_max/images/Ctl_Unit_AirRegB.jpg)
![](http://members.rennlist.com/t_max/Radiator_Fan_Control.gif)
P.S. at one time I looked up the wire diagrams for this and from what I remember, it "should" be a plug and play swap from as far down as 1989.
Range Master
Pepsie Lite
Pepsie Lite
Cool, thanks Tmax.....I will show this to Jim.......
