What do we do for speakers?
#31
I would recoomend these http://www.blaupunktusa.com/Blaupunk...ent/PCc660.htm
Mount the tweeters up high and add a sub. You can still use the original grills. Not as hard on the wallet as the MB's.
#32
Here’s the stereo setup on my 90’S4:
Blaupunkt Honolulu (4x40W)
- speaker output for front and rear with fader adjustment
- pre-amp outputs for external amp.
Head unit directly driving
-front 4” woofers & tweeters
-rear 4” woofers.
Sony XM-222W 2-channel power amplifier
- located in factory booster amp location
- driving rear 6.5” woofers and tweeters
Speakers:
10 speaker system using factory locations, crossovers, and factory grills
Speakers:
2 - MBQuart 6.5” single cone woofer mounted in cutout of factory speaker
2 - 4” dual cone, 40W, 1.5” mounting depth, mounted in front
2 - 3-1/2” dual cone, 40W, 1.5” mounting depth, 4” woofer locations.
4 - factory 2” tweeters front and rear
-rear 4” woofers.
Speakers:
Speakers:
#33
Check out www.partsexpress.com for the foam surround repair kits. They also sell perfed metal speaker grills in all sizes. They look fairly close to the originals, yet are pretty indestructable. I used them to replace all of the factory grills in my car. I used to own a car stereo shop and the 928 is a pretty tough car in a lot of respects, not much room, pain to integrate aftermarket w/factory, etc. I have found a great little 5 channel amp bt INTERFIRE. I'm using it for front, rear, and mono sub. Probably 300 real world watts.(dealer cost $130.00) Hope I helped, Rick
