A/C Relay replacement
Ok folks, I am about to replace the A/C relay in HVAC head unit in my '94 GTS. Sometimes the A/C works fine, like about 10 days ago. This week, nothing.
The existing relay looks to be a 2 amp unitSDS Relays, DSP2a-DC12V. I bought the Radio Shack 10 amp relay, 275-0218.
I have printed Dr. Bob's diagram and instructions (note to self, get magnifying glass to read the .pdf file from Dr. Bob).
Can anyone tell me where to get a solder wick or vacuum desoldering tool? I will make a call to Radio Shack tomorrow. Hope to get this done on Saturday morning. When the A/C works, it blows nice and cold, about 33 degrees F from the top vent.
I will take pics and post when done. Wish me luck.
Radio Shack will have the solder wick. Generally I find it easier to remove components like this using a very narrow-nozzle heat gun to heat all the pins simultaneously. When they are all melted, pull the relay then clean up the holes with solder wick and a soldering iron. Solder wick alone will not be enough to completely desolder the old pins. Also, the little spring-loaded "solder sucker" vacuum unit is going to be useless if the circuit board has that heavy varnish on it. They are nearly useless under the best of circumstances.
Went to the electronics store at lunch today. After softball game and some dinner (with adult icy cold beverage), I go to the garage. Now it's 2.5 hours later. The A/C relay is changed out, everything is back together and.........IT WORKS!!
Desoldering suction tool.....................$15.75
Solder wick.............................................2.95
18 guage wire, 25 foot rool....................3.99
Solder.....................................................1.69
Shrink wrap, 4 foot piece 1.40
10amp Radio Shack relay, 275-218 8.50
Head unit relay replacement successful................PRICELE$$
For everything else, there's MasterCard
Best damn 3 hour project ever. Thanks to Dr. Bob for his excellent writeup and the recent posts that detailed this project.
http://forums.rennlist.com/upload/as..._side_view.jpg
