Seatbelt light will not go out
Trying to fix some niggles that have been bothering me for a while. On my '91 S4, the seatbelt light will not go out. I've tried to figure out if I have a bad belt connector or a break in the wiring. Appreciate any hints. Thx
Thx for the response Dave. I took the seat out when I reupholstered it and don't think I had an issue with it at that time, but I will recheck. I also have an ABS light on and that might be throwing the seatbelt light on by itself. Lot's of small bugs to work out.'
Jesse
Jesse
Babado (09-13-2024)
Hey John
I disconnected the receptacle wires to see if I could check continuity, bad receptacle, but didn't get any worthwhile results. Decided to check with the hive mind before going any further.
I checked continuity with the buckle engaged and not engaged and got no continuity either way. Like I said, the results confused me and I decided to seek help here. Results would indicate to me that there is a fault in the buckle receptacle, but that seems unlikely.
