1987 928S4 Automatic Belt Tension Dash Light
Hello everyone, wanted to ask a quick question on the 87 928S4 belt tension light. I am newbie to this and wondering if anyone know good resource/shop in Raleigh NC area to check it out for me.
I appreciate the help.
Thank you
Thank you
If the light is coming on after you start the engine and or when driving, you should STOP starting the car and have it flat bedded to a know 928 shop.
If the belt is loose and jumps timing it will get very very expensive (pull engine and redo heads/valve job).
There's a ton of knowledgeable, experienced folks on the East Coast so hopefully one of them will chime in to offer some advice or direct help.
Good luck
Good luck
Recommend a good 928 shop near Raleigh
Brad Moyer
Digital Chassis
Durham, North Carolina 27705
Rich
928 OC Membership Chairman
1993 928 GTS Cover Girl
1987 928 S4
1979 928 5-speed rescue
1979 928 Euro 5-liter track beast
There is also a retrofit spring tensioner option (Porken Tensioner) you can install when doing the belt and water pump - it never needs adjusting, just like a modern car. Have them in both my 928s.
Jon B. (07-24-2024)
Hello Rich, I spoke with Brad, and it seems that he worked on the same issue previously and currently working another 928 as well for different issues. He is very busy currently and asked me to contact him next week. Thank you for the information.
Jon B. (07-24-2024)
