Fighting the big shaft!
87 five speed, left rear Bilstein all set up, trying to get the shaft through, started from the front, a lot of grease. So got it to the shock but offset to the last bushing. Tried spinning and tapping on the front it’s hitting on the shoulder, pushing up with a kick stand does not help center it. Should it be put in from the rear?
Got it!, looking at the threaded end I got a flat blade screwdriver and pushed it toward the center while pushing and turning the bolt on the front and it advanced. So left side is together, still trying to get the right shaft out, double washers did not work.
soontobered84 (07-18-2024)
