Purpose of sensor?
In the duct that takes air to the alternator, there is a probe that looks like a temperature sensor, presumably measuring ambient air? Where is the
temperature reading sent?
Correct part number 928 659 021 01 ....outer sensor for automatic air conditioning . Which is NO LONGER MADE , no longer available from Porsche and without which the climate control can not function correctly when the temperature control is any where but full hot , full cold . That 's the one !
Jim, all sorts of Audis, BMW, etc have ambient temp sensors, although I don't know what they use for a climate control reference temp. Do you, or anyone know of the type and characteristics of this NLA (RTD?)sensor or where to find the specs. I would think that adaptable sensors could be sourced if the characteristics were known - or is this a long dead end topic?
Smart a$$ reply ........... be too hot or too cold .
What needs to happen is reverse engineer a replacement temperature sensor ....variable resistance based temperature unit to feed the correct signals to the A/C control head . Until then source good used units although I believe we may have one new unit left in stock .
It's a thermistor, right? With the original and a bit of test equipment the spec could probably be deduced, if not available outright. Shouldn't be rocket science finding an appropriate replacement. Worst case, inside & outside thermistors are run through a comparator and you might have to replace both.
Yup, as long as the curve sorta matches, Chris has the answer. It's a simple commonly available part (I'm sure Mouser stocks the same thing if Digikey runs low).
Just have to coat it and attach to the housing.
Greg
Greg
I got one on eBay...was in great working order and also purchased all new ducting from a place online that sold airplane air duct...nice heavy duty vinyl with wire wound through it. Has held up extremely well.
http://www.aircraftspruce.com/catalo...p?recfer=15594
Received 1,638 Likes
FYI, I'm pretty sure the Porsche part is available again. Stupid expensive. But available.
