Part number search Fuel line from pump '78 Euro
Hi, my name is Stephen, I don't post on here often but I do appreciate the help when I do.
I have a '78 Euro and have been slowly replacing fuel lines to get her back on the road this year. One of the fuel lines that still seems to be leaking (of course it wasn't before I started fixing things) is the line running from the pump that has the banjo bolt on it. Can someone please tell me the part number for this so I can get a replacement. I am having a difficult time finding it for some reason. Thank you so much!
On a side note...suppose (hypothetically of course), that while replacing the injectors, one of the aluminum injector rings couldn't be screwed in all the way, how might this affect the drivability?
https://928srus.com/products/928-356...6IO1CNOl3uQMJA
Edit: Sorry, Stephen. Not applicable to your car..
Archive Gatekeeper
That hose from pump one to the bottom of pump two (in the rear of the right rear wheelwell) is 928 356 021 01. Highly unlikely that it's still available from Porsche. Your best options for reproductions are 928sRus or Precision Motorwerks.
Let's just say I tried several times to screw it down but I'm thinking that it may have gotten cross threaded. It seems to be sticking out about a 1/4 of an inch from how the other ones are sitting...just wondering if it is going to mess everything up, or if it's going to make it misfire...or leak?
My hose runs from the pump underneath the tank just like you said...
Archive Gatekeeper
Many hoses in the Porsche PET diagrams look nothing like they do in real life, you kind of have to reality-check what's actually on your car. And there were a bunch of different configurations of fuel pumps and hoses in 1978, so this is where pictures are worth lots of words.
Have a look above the right rear tire at about 10 o'clock, there should be a second fuel pump. The hose from the first pump with the leaky banjo fitting (in your pic in post #1) runs up to the right rear wheelwell and threads into the bottom of the second fuel pump like so:
No 2nd pump?
Sorry, my photos always look so crappy.
Archive Gatekeeper
Nothing that 5 minutes in the local carwash bay with their pressure wand won't fix. Looks like you have the early '78 fuel setup with the 2nd pump bypass pipe (kind of rare), but a replacement for 928 356 021 01 should still work for your car.
