89 and 90 simple keyless remote locking installation
Exceeding simple plug-in installation for lock/unlock only install, for 89 and 90 only.
Requires one male and one female three position Molex connector and two 1/4" ring terminals.
Yellow wires to ground. Open|white/black to brown/green. Close|white to brown/red. (Note, O/C plug markings are on the flat side of the Molex.)
I removed all the other wires from the plug for simplicity. (Push down on the exposed retaining clip and pull out terminal.)
Plug at passenger door to place the passthrough. Pre-89 this is the alarm connection. 91-up do not have this plug.
Red to CE panel, black to ground.
I just could not wrap my head around what I thought would be a simple installation, until I came upon this post, amongst the pages and pages of keyless remote threads, most focusing on the useless-to-me hatch output. https://rennlist.com/forums/928-foru...l#post14013315
There are many cheap boxes to buy but they pretty much all have the same wiring. I used this box from Amazon - B088D7R8LG, because I wanted two buttons only. The metal fob has a nice weight to it. (Holding the unlock button for 1.5 seconds triggers the hatch output.)
Cool! It looks like that was my post that you referenced, so I'm glad that it was of use to someone. I like the cleanliness of this installation, so if my unit ever gives up the ghost I will look into something similar. Thanks for sharing!
Added the turn signal lock verification wiring. Not being sure if it locked from a distance turned out to be quite annoying.
The box wiring came with two large diodes for left and right turn signals. Continuing my low impact installation, I used flat terminals, slightly bent at the hole, jammed into the CE panel 'P' plug at P11 and P12 and secured with a zip tie. (Black/green and black/white wires.)
