LOST KEY
The following 3 users liked this post by Rob Edwards:
Got a photo of the key? If so send it to https://www.keys4classics.com/vehicles/porsche/928/
WestInc (01-23-2024)
The following 5 users liked this post by Jason89s4:
CliffH (01-24-2024),
linderpat (01-25-2024),
RTK (01-24-2024),
smsarchitects (01-24-2024),
I only had one key when I got my 1987 4AT, tried the dealer but got a key that was nothing like the one I had, which works every lock on the joint perfectly. The dealer said the success rate for these keys was not high and they weren't going to order them for older cars anymore.
It's straightforward to get a door lock out and read the tumbler plate codes.
If you are running around with just one key it's a great idea to take good clear pictures of it and an even better idea to then order one (or some) from keys4classics before the old torn shorts in which you left the only key get thrown out.
RTK (01-24-2024)
Agreed with others - when you receive the key from the dealer, test it to ensure it works, then take pics of both sides and get extras from keys4classics. Note that there may be an alarm key (red) vs. regular key (regular key is black and shorter.) Keys4classics can make you a standard key from the photos of an alarm key.
Shirah (01-24-2024)
IIRC the Red key is the Valet key (non Alarm) and is shorter. All Alarm keys are longer to engage the Alarm switch that is an additional section at the end of the Key cylinder.
Edit: not sure when the factory alarm came as standard equipment 1984 or 1985 and up
Dave K
I don't think that's correct, Red versus Black key.
Dave K
Dave K
davek9 (01-26-2024)
