Help needed with the gray 9 volume workshop manuals - I might be missing pages
Administrator - "Tyson"
If you have a set of these, plese open:
Volume I - A
Engine
Page 24-24
On mine it's showing how to correct CO level on the air flow sensor.
The next page jumpt so 24-101 showing the LH-Jetronic equipment table.
It seams like 76 pages or so are missing.
On page 24-22 I have the hose diagram for the AFC. What I need is the hose diagram for the piece that the TB bolts to.
On page 24-102 it shows the diagram for the above for a 16V LH car. It looks like the same configuration as mine, but I'd like to be sure and have the digram for my manuals.
Volume I - A
Engine
Page 24-24
Inventor
PDF's too.
It's supposed to be like that. It's not elusive, it doesn't exist. If I'm wrong, then do you have page 24-128?
24-14 shows a decent pic of the vac. lines. Hacker, mine is apart if you want me to take some pics tonight.
Let me know.
Let me know.
Originally posted by jon928se
My 9 Volume set is the same
Isn't Item 10 on Page 24-22 the TB cunningly described as Throttle Housing.
Jon
Black SE
If it aint LH I'm lost
Jon
Black SE
On page 24-102 they show this setup for the LH-Jet 16V setup. I'm sure they are the same, but wanted to make sure, then I pulled out my parts and found someting connected to the above pieces not listed. I'm assuming it's part of the emmisions equipment I've taken off, but wanted to make sure. Here's a picture:
![](http://forums.rennlist.com/upload/mystery_part.jpg)
![](http://forums.rennlist.com/upload/mystery_part_2.jpg)
HP,
If you check the table of contents on page 2, you will see that pages 24-25 through 24-100 were skipped. The picture is an EEC (evaporative emissions control) valve. It controls the release of vapors from the charcoal cannister and fuel tank into the intake.
Dennis
Dennis
