928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine connector question
Old Dec 12, 2023 | 01:33 PM
Babado's Avatar
Babado
Default Engine connector question
Hello all, newbie question, I've searched to no avail.
86.5 engine bay plug just behind and below the crossbar, 2 prong female plugs onto male.
While searching I noticed it was unplugged, plugged it in, haven't fired the car up today will wait out of curiosity.
​​​​​​ Thanks
Old Dec 12, 2023 | 02:25 PM
davek9's Avatar
davek9
I think you will find that it is a 3 prong, and it goes to the Throttle position switch on the throttle body.
Old Dec 12, 2023 | 02:42 PM
Babado's Avatar
Babado
You are correct, when I last parked it (70 mile drive) it was running great, I need to research what this switch does now. Thank you
Old Dec 12, 2023 | 03:34 PM
davek9's Avatar
davek9
The switch is a critical part of engine management as it tells the ECU's which fuel and ignition map settings to use when: at idle, cruse and full throttle.
Old Dec 12, 2023 | 05:08 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
NOTE Roger sells a replacement short harness that goes from that metal bracket to the TPS.
Old Dec 12, 2023 | 07:30 PM
Babado's Avatar
Babado
Thank you again, plugged the 2 connectors back together went on a 20 mile drive, idle, acceleration and cruising is all good.
Old Dec 12, 2023 | 08:25 PM
linderpat's Avatar
linderpat
weird that it as unplugged, and that the car still ran well!
Old Dec 12, 2023 | 08:29 PM
MCR 85 928's Avatar
MCR 85 928
What's the name of that part or part number Mr Merlin? I need one.
Old Dec 12, 2023 | 08:33 PM
Babado's Avatar
Babado
Hi Ed, after hearing what it was I surprised too.
Hopefully someone will chime in as to why it ran well unplugged, unless it just happen to pop off after the 70 miles. Checked it after the drive today and it was still connected.
Old Dec 12, 2023 | 08:39 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
For an 86,
TPS short Harness,
just call Roger and ask him for it
817 430 2688
or send an E mail Roger@928srus.com
