Blink'R Assembly Question
I finally got all the parts to make a Blink’R using Pokens and Skpyle’s instructions from a few years back but I have a question and need some clarification so I don’t inadvertently damage my ECU.
Is this the correct solder points?
The RED led connected to the 680 ohm resister and soldered to post “A”
The YELLOW led connected to the 100 and 10 ohm and soldered to post “B”
The toggle switch lead are both ground wires and are soldered to post “C”
PORKENS instructions: https://rennlist.com/forums/928-foru...-85-86-us.html
SKPYLE thread: https://rennlist.com/forums/928-foru...a-blink-r.html
John
John
I don't remember which are A, B & C, but you can follow the wire colors >>> here <<<.
Team Owner
please post pictures of your part you created and what the layout is,
thanks !
thanks !
