Fuel gauge issue
Fuel gauge issue
My fuel gauge is only reading empty, and the red light is on
i replaced the sending unit with the 944 unit, but still no joy with the gauge
yes, there is gas in the tank, about 7 gallons
any thoughts on where else to check?
the connection at the sending unit is nice and clean
is there a way to put power to the sending unit connection and see if there is any movement at the gauge?
Mrmerlin (10-29-2023)
Otherwise remove the sender and tilt it up so the float moves with the key on run
observe the gauge
NOTE its possible the needle will stick on its internal stop,
this will sometimes stop if the car is used more frequently
observe the gauge
Yup, when the new foil went in 18mo ago, all were off cleaned, etc, etc..
These 2 gauges were not happy before this, and doing this work did not change their behaviour.
Sender is new from GB stock as well.
