Windows/sunroof non op
Took one of the 86.5s' for smog today (First time on the dyno) (it passed) and I noticed the windows would not roll down. Car has been sitting for awhile (6 month) also the sunroof will not open.
I am about to pull fuse/relay panel to see if something is amis (fuses are good) but I thought maybe a quick inquiry here might save some (or a lot) of time and frustration. Is there anything I should/ could do before undertaking fuse panel removal? Any help or suggestions are greatly appreciated
There is a single relay & fuse for both - so I'd check the fuse electrically (not just visually or by changing it) and swap the relay before committing to removal.
Alan
Alan
I would replace the window relay before trying anything else if the fuse is intact. You can test the circuit with a 53 relay as the 5th pin just sends power to the door locks when the car is off.
