Lowering ride height on a 928
Hi all,
Just picked up a 84 928 (auto), installed new boges all around. Ride height is way up (looks like a 4x4). I noticed the rears have somewhat an inverted coilover from the factory and looks like it can be adjusted via perch. I looked at the front and didn't see anything, is there a way to lower the fronts?
I will play with the rears using perch adjusters that I used on my 964 suspension, just wanna find out is there a way to adjust the fronts?
GP
GP
The front Boges should have adjustment as well...........but you must drive the car for at least 50 miles to get the suspension properly settled before you make any adjustments to the ride height. It will take that long to settle down.
When I installed Boges all around, my car also looked like a 4x4. It took almost 500 miles for the car to settle. I would do at least one month of driving before adjusting. The Boges take allot of driving for them to settle at first. After that, it only takes about 50 miles every time you jack up the car.
The bolts holding the rear bearing on the lower control arm should be tightened when the car is sitting on its wheels and the suspension has settled, if not the front will never settle to the right height.
P 40 - 15 workshop manual.
Under the Lift
