928 Forum 1978-1995
Sponsored by: 928 Specialists
Rubber gasket at back of thermostat housing: friction fit or needs adhesive?
Old 05-16-2013, 11:21 AM
Mike Frye
Craic Head
Mike Frye's Avatar
Tom,
I agree if the T-stat is bad or the seal is missing. But disagree with the suggestion that a lower temp t-stat is going to fix his temp situation when sitting in traffic. He said his original diagnosis/question was based on the T-stat being the 'stock' temp and he wanted to go lower. My assertion is that if the stock t-stat is working as advertised and he's having this problem, the issue isn't going to be solved by changing to a lower temp t-stat.
Old 05-16-2013, 11:31 AM
SteveG
SteveG's Avatar
There is a small hole, I guess less than 1 mm, through the T-stat. Do you mount with this at the top, side, bottom, or does it matter?
Old 05-16-2013, 11:35 AM
newworld
newworld's Avatar
Default tstat
the small hole is the jiggle pin, should be at 12 oclock. it is an air bleeder.
my question is this, when i installed the rear seal, and tstat, i can see a gap, so i assume the coolant when cold circulates thru the rear seal and the block and not the rad.
when temp is reached then the tstat expands? and closes that gap and seals with the rear seal?
Old 05-16-2013, 12:23 PM
Tom. M
Deleted
Tom. M's Avatar
Yep...that's the way it works..
Old 05-16-2013, 12:28 PM
Tom. M
Deleted
Tom. M's Avatar
True on the surface...but when I put my lower temp t-stat in...the car ran cooler (gauge) in all conditions I drove.. I don't sit much in traffic, and yes, when sitting in stop and go traffic in Wichita last OCIC (100 degrees plus), the temp gauge was where it was before I added the lower temp tstat....
I like the lower temp t-stat simply because it starts working sooner and the "ramp" up to operating temperature is slowed (for my usual driving patterns).
For colder environments, this might not be good...especially if you have a shorter drive..
Originally Posted by Mike Frye
Tom,
Old 05-16-2013, 01:51 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Is it possible that something else changed when you did that T-stat change? You had to drain the coolant system, maybe you flushed it too? Did you clean out the radiator fins or find some leaves in there and pull them out? Maybe just the act of draining the coolant and refilling it dislodged some obstruction from the radiator or some coolant passage in the engine? Maybe the old Tstat wasn't opening all the way and the new one does?
I just want to make sure anyone following along understands the function of properly functioning T-stats of two different temps is exactly the same when fully warmed up, or at least they should be.
Old 05-16-2013, 02:05 PM
Tom. M
Deleted
Tom. M's Avatar
Im not disputing that... but the way I look at the cooling system is like this (poor analogy, but best I can think of at the moment)...two pots of water on the stove..one 2 quarts...the other 4 quarts.....both burners on high..
the one with less water (e.g. stock thermostat that stays closed longer keeping the volume of coolant in the block longer)...will boil first.....
the one with more water will take longer to boil....(t-stat forces water in block to mix with cooler water in rad sooner giving a cooling effect from both volume and the efficiency of the rad)...
but in the end... you are correct... and both pots end up boiling
Old 05-16-2013, 02:45 PM
69gaugeman
69gaugeman's Avatar
Likely the changing of that rear seal would cause your car to run cooler. That seal is a bypass from the rad so it would bypass some of the rad coolant and just recirculate it if the seal was not working properly.
Old 05-16-2013, 02:51 PM
Bilal928S4
Bilal928S4's Avatar
The Porsche engineers designed the engine to run at a certain operating engine temperature. This final temperature is the most efficient and environment friendly. Why would you want the engine to take longer to get to it's preferred/designed operating temperature?
Old 05-16-2013, 02:54 PM
Tom. M
Deleted
Tom. M's Avatar
I'm guessing that their final preferred/designed operating temperature was more suited to fuel economy ...over performance.. But just a SWAG..
Old 05-16-2013, 05:34 PM
69gaugeman
69gaugeman's Avatar
The hotter an internal combustion engine is, the more efficient it is. Unfortunately we have to live with materials that melt before the efficiency is 100%. Being more efficient means a cleaner burn. If it wasn't for cold starts the cat would not be needed at all as, when the engine is hot and running normally it burns clean. The cat 'burns' unburnt fuel (think WOT or start-up) and other than that it runs perfect.
Old 05-17-2013, 01:18 AM
sstrickstein
sstrickstein's Avatar
Ok so today after replacing my t stat I drove the car to work. Same route and conditions. The highway temps were much lower and the in town stoplight never saw the 2/3 mark. Since I have a 944 and it behaves the same after a complete drivetrain rebuild, I will call this one done. I also consulted with an expert here In Phoenix, Jack at Stutgart Southwest on Tempe. He told me he has seen some cars with them and some without, He has rarely seen any difference in the operation. He did suggest any further work should revolve around the Clutch fan. I read a article online about rebuilding the clutch fan. I am going to look into this as well. However, I wont replace the Fan clutch, I would install a Electric fan kit instead.
Old 05-17-2013, 01:52 AM
Hilton
Hilton's Avatar
Early cars don't have it (I think it was only fitted from '84? certainly 83 "Euro" don't have it)
Old 05-17-2013, 09:50 AM
jeff spahn
jeff spahn's Avatar
Why would you put a flush kit in the car? Simply open the block drains and your coolant will be all out.
Old 05-02-2016, 02:41 PM
crushingday
crushingday's Avatar
Default Thermostat inner seal
Does my '78 have this rear seal?
I was under the impression that it may have been introduced in a later model
Quick Reply: Rubber gasket at back of thermostat housing: friction fit or needs adhesive?
