Accelerator cable
What is the trick to remove the accelerator cable from the top of the petal?
is it even possible without removing the seat?
it seems like the only way is if you have ET arms, I can’t even contort myself enough to even reach the connection.
any photos or a decent video would be great, everything on YouTube sucks
thanks
thanks
Move the seat all the way back and use some gymnastics skills while on your back on floorboard. Now is the time to make sure you have all tools and flashlight with you nearby once you’ve contorted into place. Bring a 10mm socket and wrench and clean the grounds up under dash while your there.
Or remove seat and steering wheel and have plenty of room!
-Jason
-Jason
