928 Forum 1978-1995
Sponsored by: 928 Specialists
Won't run
Old 09-21-2023 | 07:04 PM
hacksaw's Avatar
hacksaw
Default Won't run
I parked my 1984s auto a few months back. It was running great. It sat for a couple of months and now it will not run. It cranks over fine and tries to start but as soon as I release the ignition key it goes dead. It has a new fuel pump relay and fuel injector relay and good fuel pressure. It seems to stop firing when I release the switch.I hooked a test light to the positive side of the coil to see if it was getting power when I released the key. It cranked right up and ran fine with the test light hooked up. I disconnected the test light and it continued to run. I shut it off and it reverted to the earlier behavior. It runs with the test light hooked up but no light no run. It seems to need that little bit of resistance to keep the coil firing after cranking. Is there a resistor in that coil circuit that could have failed?
Any suggestions would be appreciated.
Old 09-21-2023 | 08:28 PM
karl ruiter's Avatar
karl ruiter
I think there are two resistors. One for cranking and one for running maybe. Cannot find a picture of them, but here is a diagram:
https://rennlist.com/forums/928-foru...resistors.html
They are on the fender wall near the coil, I think.
Old 09-21-2023 | 08:48 PM
hacksaw's Avatar
hacksaw
Thanks. I'll check it out in the morning
Old 09-22-2023 | 11:14 AM
9two8's Avatar
9two8
Are these the two resistors your referring to ?
Ken
80 928S
5 Speed
UK
Old 09-22-2023 | 12:07 PM
soontobered84's Avatar
soontobered84
That is them.
9two8 (09-22-2023)
Old 09-22-2023 | 08:05 PM
hacksaw's Avatar
hacksaw
Thanks. I found them where you said they would be hiding. Beru WZR-04K and Beru WZR-06K
I wonder if Roger has them.
Old 09-23-2023 | 02:56 AM
The Forgotten On's Avatar
The Forgotten On
He and Mark A both keep Mercedes alternatives in stock since the original ones went NLA years ago. They're cheap to replace as well.
You can test to see if they went bad by bypassing them. If the car keeps running, you've found your culprit.
Just don't run the car with them bypassed for extended periods of time as the coil will get cooked...
Old 09-23-2023 | 09:22 AM
hacksaw's Avatar
hacksaw
Quick Reply: Won't run
