928 Forum 1978-1995
Sponsored by: 928 Specialists
Might need a hood...
Old 05-23-2004, 01:49 AM
John Struthers
User
John Struthers's Avatar
Unhappy Might need a hood...
Picked up Zack's White 81' from the frame benders on friday.
They did an excellent job repairing the -nose- front bumper cover/fascia.
However, they were unwilling to straighten the right side hood hinge.
So I ordered and recieved one from 928 INTL in two days -thanks guys-.
Alas! When I went to pick up the car I discovered that rather than use two people to align and adjust the hood hinges for proper latch alignment they only used ONE.
There is now a slight twist and a small new kink about 1 1/2 inches long with attendant crack in the paint . Of course as the old saying goes...,
" it was like that when you dropped it off".
Anyhow, I will try to fix the damage , assuming everything goes wrong...I might be in the market for a GOOD HOOD in the next 5-6 days. Preferably in Arctic White but I'm flexible.
Looking for cost to be under Big 3.
Should I use a 9" roller with stucco nap, or, the factory recommended 6" wide whitewash brush? ( For front end touch-up).
Old 05-23-2004, 03:28 AM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Rollers work best, John! They give you this upscale trailer park look that is so unique among all the brush painted cars in primer grey...
Old 05-23-2004, 04:07 AM
SharkSkin
SharkSkin's Avatar
Default Re: Might need a hood...
Wagner power painters work very well for exterior latex. For big jobs, get multiple tips because they erode.
Old 05-23-2004, 04:30 AM
2V4V
2V4V's Avatar
Default Re: Re: Might need a hood...
You guys and all yer fancy schmancy tools. Just pour the paint right out of the can. Gives it an artsy touch and covers driveway stains at the same time...
Greg
Old 05-23-2004, 04:45 AM
Jadz928
Jadz928's Avatar
John,
I would give you the hood off mine, but I'm using it to hold up the hood shocks. hehe ...wish you well.
Old 05-23-2004, 04:56 AM
SharkSkin
SharkSkin's Avatar
Default Re: Re: Re: Might need a hood...
Greg
Great idea Greg... a Jackson Pollock hood!
Old 05-23-2004, 07:33 AM
Garth S
Garth S's Avatar
John,
You're too far inland for a flock of seagulls, for they do the best work: however, in Midland - park it under a tree full of pigeons for a day or two. You're sure to get a whitewashing that would make Jackson Pollock envious!
Old 05-23-2004, 08:05 AM
Thaddeus
Deer Slayer
Thaddeus's Avatar
Default Re: Re: Re: Re: Might need a hood...
Don't give Porsche any ideas. Those Stuttgart dudes seem to have these inexplicable, and drastic, failures of taste from time to time....
Old 05-23-2004, 08:57 AM
Old & New
Old & New's Avatar
John,
Clean out your mailbox & I'll send you details of my spare hood.
Old 05-23-2004, 10:04 AM
Dennis Wilson
Dennis Wilson's Avatar
John,
Using those methods to paint the hood will take WAY too long. Get a straw bristled street broom and load it up with paint. That straw soaks up an enormous amount of paint. After painting the hood you will probably have enough in there to touch up the rest of the body. After you paint it, give the youngun about 200 sheets of 2000 grit wet dry and tell him to color sand it. BTW if they mounted one side of the hood too low and tried to open it normally, a bend like like the one you described will occur (almost BTDT).
Dennis
Old 05-23-2004, 12:24 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
No, no, no, no. That requires too much effort. For a less discriminating customer, in Atlanta all you have to do is follow a painter's truck on 285. Sooner or later the entire car is painted as you drive and dodge the 5 gallon paint pails. Combines auto cross and an Earl Schib paint job.
And that includes windshield, tires and wheels. For free!
-Kevin
Old 05-23-2004, 02:06 PM
Dennis Wilson
Kevin,
I haven't been lucky enough to get my cars painted that way. I have had my newly painted cars front end shotpeened by the local gravel haulers. Also, I was lucky enough to get my front panel stripped of paint by a road crew using solvent to remove temporary stripes from the road. Got any more great shortcuts?
Dennis
Old 05-23-2004, 03:41 PM
John Struthers
User
Thumbs up
After careful consideration of the many creative painting techniques offered at -unbelievebly- no charge by my fellow renn-listers and friends locally I've
whittled it down to several promising comprimises.
Pay attention Snow,
Kevin,
They just shut down our Oddessa District strpping crew so following the stripping crew is no longer an option. However, I found out where they stashed the last 55 gallon drum of traffic white and the two remaining 40lb bags of reflective glass beads. So, all is not lost!
Nicole,
I agree, nothing turns heads faster than a Primo roller job, and especially, if you wait for the paint to tack and roll it 'one more time' . When it dry's the surface makes those pesky June Bugs shred when they bang into the hood at speed. Some of my 'friends' here in Midland have suggested using that lovely splatter paint used in the trunk area of cars living in the rust belt
for exterior ambiance. While others have offered to help do a one of a kind total repaint using Rhino Liner with a 3/8" nap roller. Uuummmm Good!
Garth,
Dietary consistency and resulting 'product' is a problem here.
I have consulted with several paintball clubs who are currently working out the geometry of overpass/tree shots and the requiered color/quantities of paint and CO2. A more consistent texture, eh.
Dennis & Greg,
Using the pour and sweep combination seemed promising at the outset but due to the incessant heat here, when I tried this method on my neighbors' new Suburban I forgot to consider the 'sheeting phenomena'.
So, basically, the paint dried in thick sheets from all the bottom edges of the big chev' and then puddled at all 4 tire contact patches.
They should be able to cut it loose by thursday. I'm not sure if he know's I did it or not. But, hey! You didn't hear me whining when he chemically edged my sidewalk, our property line, and dual alley line with a Pathfinder/Transline/and Round-up Pro cocktail. I've been told that in two or three years I might be able to plant new trees, shrubs, grass and rosebushes with a least a 50% survival rate..
Doz,
Yep, found them. Still need the left front splash shield though.
My nterest is piqued.
Talk to me about the Hood.
jpstruthers@***.net
Old & New,
I've had a message from Beth Locking up my PM since April. It's the only thing in there...
Contact me at
jpstruthers@***.net
Old 05-23-2004, 03:49 PM
Kevin in Atlanta
Originally posted by Dennis Wilson
Kevin,
Dennis
Not for painting, but have seen a couple of novel ways to empty a radiator without even stopping. It does involve road debris.
Old 05-23-2004, 04:09 PM
Dennis Wilson
Kevin,
That radiator draining technique is a good one. I'll file it with the rear sway bar droplink removal procedure I've run into (literally).
Dennis
Quick Reply: Might need a hood...
