30 lb Ford Motorsport fuel injectors
I am looking for some 30lb ford motorsport injectors for my car. I remeber getting the factory ones for about $200/set of 8 previously. Anybody gotten some recently. Who do you recommend.
Thanks!
Thanks!
Follow the link below to" fuel injectors, Ford". There are several sets of new & used, one set at ~$85 with 1000 miles use.
http://cgi.ebay.com/ebaymotors/ws/eB...478806467&rd=1
I just picked up a set of 19# Bosch D5B 4- hole style new for <$100.
PS the 928 requires different spacers and a larger O-ring size - do you happen to know the size/source?
edit: or this, http://cgi.ebay.com/ebaymotors/ws/eB...479493842&rd=1
I can get the filters/baskets if you need more. ~$4 each. Might be able to get them an bit cheaper though, I'll check Mon.
I assume these are for one of the later cars (87+) ?
Greg
Greg
If your running a stock exhaust system or even one that is a bit mod'ed, I would not recommend 30lbs injectors. I ran them for a while and found that the little bit of HP/TQ (read very little) they added was not worth the extra cost in gas.
Now if you have a good set of headers with free flowing pipes and an adjustable fuel regulator, go for it!
I have a brand new set of Accel 24# injectors still in the box for sale if you're interested. I decided to stick with the 19# and bought a set so I'm selling the 24's. They have the O rings and backup rings but they are the Ford ones and you will need a set of kits for the 928 including the caps. I know of no way to get the caps off to change the seals without destroying them. I got some on Ebay a while back for a couple of bucks each but I don't remember from whom. PM me if you're interested (anybody). $230 new from Jeg's, $190 plus postage and they're yours.
Ok, I have tried to research this and have gotten conflicting information about the stock injector size for my car. Thanks Andy. In that case, I have a set of brand new 19# Accel injectors for sale! (heh) I have lots of Porsche documentation and I have not been able to locate this information anywhere yet. (Maybe I just didn't look hard enough!) Where did they hide this spec? I haven't found it in the WSM or the LH manual or the PET or the parts microfische and it doesn't appear to be marked on the injectors. The only thing I didn't do is ask here! I shoulda done that first although I did do a search through the archives.
