Cold Start issue on 89GT
#33
Received 1,682 Likes
And, at least for the WOT-side on the switch, can’t cause the cold-start issue.
I think you have two issues: lean idle and cold-start. Interrelated, but curing the former, might help/change the latter.
Do you have the ability to smoke test the intake? (Inexpensive, but useful, smoke machines available on ebay, etc.)
Do you know how to test basic ISV operation from the LH connector? (Instructions in my inspection guide on the openroad dot site.)
EDIT: You tested idle switch. Have you tested idle-switch at LH/EZK when cold AND warm? Or just one or the other? If so which one?
#34
So just to recap, I’ve got two issues going on.
1) The original reason for my post is, the car will not go through the high idle circuit on startup, actually it won’t even stay running for the first few minutes after start up. Once the engine has a small amount of heat...it runs perfectly.
2) The second problem that cropped up after the first issue was the lean running condition. As seen in the video
#35
I have the pressure tester for the intake (as per Dwaynes intake refresh) I can test again...maybe something has changed.
I'll have a look at the ISV operation (its new too) as per your write up.
I just replaced the TPS because the switch was not seating properly at idle (car wouldn’t idle when it was warm). (eg. no click) That fixed that issue. But correct me if I’m wrong...but wouldn't that mean the switch is functioning properly?
#36
I have more diagnostics to describe, but that description will require a real keyboard as opposed to an iPad’s touchscreen. Thus, will need to wait until I’m back from Camp928.
kmascotto (06-07-2023)
#37
Cold-start lean pretty much has to be false air, ISV, or no warm-up enrichment. Or, funky electrical gremlins.
Once the O2 loop kicks in, is the idle close to 14.x?
Stock injectors?
#38
I posted a video above which will give you an idea of the AFR at difference RPMs
I cant remember how long it held pressure when I last checked it, but its easy to do so I'll try again. Ill post a video when its done.
#39
#40
Former Vendor
I’m in need of a little help:
My 89GT is having a hard time running after initial start up (engine at room temp). I’m at a loss for what’s causing the issue. I can keep the engine running by modulating the throttle for the first few minutes and when a little heat builds it functions perfectly. Restarting the engine when its warm, there is no issue at all.
Here is what I’ve done to date.
Thanks for your suggestions
Kent
- New temp 2 sensor which has been tested (2.65 ohms @ both prongs to ground, room temp)
- Tested the continuity between Temp 2 and LH (pin13) and temp 2 and EZK (pin19) plugs (both good)
- Resistances to ground at both LH (pin 13) and EZK (pin 19) was 2.3 ohms for both.
- Replaced LH and EZK computers with no change
- Replaced MAF with no change.
- Replaced fuel regulator and both dampers
- Fuel pressure gauge on rail show 55 psi
Kent
After a few minutes of running, the O2 sensor gets warm enough to modify the "base information", that the MAF provides.
There's a limit to how much the O2 sensor can modify this signal.
Your issue is a textbook aged "MAF" providing a signal that is too lean to correct, completely.
Terribly lean on start-up and then too lean for the O2 sensor to completely correct.....although the O2 sensor helps.
BTW....there's a huge variance in what the word "rebuilt" means in each and every part you will buy.
In the case of MAFs, there's a huge variance.....and even the very best of the "rebuilders" can have a MAF slip buy that doesn't respond correctly.
Your car (in my shop) gets a different rebuilt MAF off of my shelf...long before you typed your first post.
And yes, I understand that this is way easier, for me than you...I've got a shelf full of these items....you probably do not.
So, your other alternative is to beg/borrow a Sharktuner from someone, hook it up, go drive it 10 miles, and actually see what the O2 sensor correction factor is.
ZEUS+ (06-08-2023)
#42
For my own knowledge Greg, I thought I read that to use a Sharktuner you need PEMs, or maybe I mis-understood.
Also how does the Sharktuner tie in to get an O2 reading?
Really interested in these two answers. Please and thanks
Kent, as an fyi, my Canadian(Florida-Snowbird) neighbor who has since returned home has a Sharktuner and he lives in Toronto.
He has a Koenig Specials (silver). He hasn't posted in a while.
#43
In the simplest of terms, the late model 928 fuel injection relies on the MAF and the water temperature, when completely cold.
#44
