928 Forum 1978-1995
Sponsored by: 928 Specialists
Cold Start issue on 89GT
Old 06-03-2023, 02:24 PM
kmascotto
kmascotto's Avatar
Originally Posted by FredR
Why are you using GTS multi prong plugs?
Fred, I’ve been using them for years
Old 06-03-2023, 02:48 PM
Adamant1971
Adamant1971's Avatar
Received 1,060 Likes on 504 Posts
Originally Posted by kmascotto
Unfortunately I don’t have an oscilloscope.
I have one if you need it.
kmascotto (06-03-2023)
Old 06-03-2023, 09:55 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,437 Likes on 1,366 Posts
you should be using Bosch silver tips ,
they are about 2.00 each,
part # 7900 Bosch
kmascotto (06-04-2023)
Old 06-04-2023, 03:00 PM
kmascotto
kmascotto's Avatar
part # 7900 Bosch
I’ll pick some up
Old 06-04-2023, 04:18 PM
kmascotto
kmascotto's Avatar
Default CPS
I took a closer look at the fairly new CPS sensor in the car. Both ends are in good shape.
Old 06-04-2023, 04:37 PM
kmascotto
kmascotto's Avatar
Default CPS
Old 06-05-2023, 09:48 AM
FredR
FredR's Avatar
I fail to see how a CPS sensor can cause a lean condition but your NBO2 sensor most certainly can.
The male connector on the CPS sensor can and will disintegrate after 15 plus years of service as will the 3 pin male junior powertimer connectors on the Hall Trigger, the knock sensors and the idle switch connector. Why this happens when the female connector it slides into invariably is perfectly OK fascinates me given I have no answer for this phenomena. One might think the male connector would be more protected.
Old 06-05-2023, 12:10 PM
kmascotto
kmascotto's Avatar
Hi Fred, as you suggested, I replaced the NB02 because as you noted, its the most likley reason why the A/R is off...but it didnt make a difference.
I will say that first noticed the change in the A/F after adding fuel injector cleaner (I may have been a little to generous with the fluid) Ive since emptied the tank and refiled the car with fresh premium fuel. Currently at idle, its hovers around 16.5, at about 2500rpm if around 14.7...so thats good.
I'm still dumbfounded as to why the car won't go through the cold start high idle process.
Old 06-05-2023, 12:52 PM
FredR
FredR's Avatar
Hi Kent,
Suggest you check your temp2 sensor resistance values when cold- should be around 3k to 4k ohms as I recall dropping to about 200 ohms when warmed up. Check both channels pin to earth
kmascotto (06-05-2023)
Old 06-05-2023, 03:53 PM
Zirconocene
Zirconocene's Avatar
Honest question for the good wrenches here: why not check the ISV, in this case? Prior to the lean condition, that's where my thoughts went but I'm looking to learn and improve my diagnostic skills.
Good luck OP, you've got the Wolves helping your shark.
Cheers
Old 06-05-2023, 04:23 PM
kmascotto
kmascotto's Avatar
Cheers
im going to try everything possible before I pop off the intake again. The isv is only a few years old and there aren’t many miles on it. That said I even added the Rogers ISV extension that last time.
Old 06-05-2023, 04:34 PM
kmascotto
kmascotto's Avatar
Default Idle video
He here is a link to the video with the car running and a WBO2
Old 06-05-2023, 05:04 PM
FredR
FredR's Avatar
Cheers
The input info was difficult cold starts and the revs were not picking up- this to me suggests the brains are not being told the engine is cold thus the difficulty becuase it will not be getting cold start enrichment.
Zirconocene (06-05-2023)
Old 06-06-2023, 11:27 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
in the CPS picture what is the wire thats wrapped with tape or silicone wire wrap?
A knock sensor wire?
Old 06-06-2023, 06:28 PM
Shirah
Shirah's Avatar
A dead WOT switch will not trigger the WOT enrichment map.
Check your WOT Switch
Peruse here:
https://rennlist.com/forums/928-foru...itch-help.html
Quick Reply: Cold Start issue on 89GT
