Hello all. I wanted to see anyone had a recommendation on wire connectors that looked similar to factory. The original side of my AC thermostat wiring protectors have seen better days and my new thermostat ones are a bit of an eye sore. Maybe a silly question but I haven’t had any success finding something that works. Also, I have the original double male to female adapter if that helps.
Those connectors are also used on MB's of the same time period.Might want to join a mercedes forum. I'm always on the lookout when I make a picnpull run.I glance at all the late 70' thru early 90's cars that they have in inventory.
If you're interested, the 944 PET has the electrical connectors listed out in a way that is not present in the 928 PET documents. It's a good place to start seeing what was used and how you might source it, on the off chance that Roger or one of the other vendors doesn't have that particular piece.
