928 Forum 1978-1995
Sponsored by: 928 Specialists
Parts number CWS Module
Old Apr 12, 2023 | 11:03 AM
Tops2808's Avatar
Tops2808
Default Parts number CWS Module
All warning lights lit up, tried to resolder the CWS Module, still comes on an off...
Tried the most, think i have to get a new/used module.
928.641.602.04 is the part number on my module (86 Euro Twin Dizzy)
Will any other CWS Modules work, and what other partnumber will work?
Old Apr 12, 2023 | 11:07 AM
gazfish's Avatar
gazfish
Are you sure you’re getting the alternator signal that turns off the initial bulb test before changing the unit?
Old Apr 13, 2023 | 03:09 AM
Tops2808's Avatar
Tops2808
Thank`s for the advise, Have not checked that,
Should i check directly on the alternator, the 14-pin connector or somewhere else?
Old Apr 13, 2023 | 04:14 AM
gazfish's Avatar
gazfish
It comes through pin 1 of the 14 pin connector, a blue wire and then goes to pin 12 of the CW unit. Worth grabbing a copy of the wiring diagram if you don’t have it to trace it through.
Old Jun 10, 2023 | 05:01 AM
Tops2808's Avatar
Tops2808
Finally got it fixed, no more funfare/disco warninglights
Ended up changing the CWS module, bought locally at just 47$
The new CWS module is from a S4, partsnumber 928.641.602.05, it has the same wiring as my 86 Twin Dizzy.
