HVAC slider lube
Does anyone know what kind of lubricant is used on the back side of the sliders inside the hvac controller?
Team Owner
I just did this today I used DC 111 on the slider run,
and D100 on the grid fingers
what are grid fingers?
Archive Gatekeeper
I think Stan's referring to the conductive traces on the HVAC head.
![](https://webfiles.uci.edu/redwards/public/Azurite%20HVAC%20head%20slider%20detent%20ball%205-4%20mm%205-8-21.jpg)
Team Owner
Yes the metal fingers that run on the circuit board grid D100
I take the E clip off then remove the fingers holder Clean the contacts and bend the fingers a bit to add pressure to them verify they all touch when you put it back together check the full range of motion
