R-R the Thermostat Housing Leak
928 Collector
I've seen so many 928's leak on the thermostat housing right up front, and now I know why. Yesterday I pulled my '85's t-bone and found the rubber had deteriorated exactly like toilet seal rubber ... you know how the moment you touch it, it pastes your fingers with black icky perished rubber paste? .... Same. No wonder those seals leak on so many cars, they are not what I would call high quality. I have the seals to replace, but will be sure to paste some nice American standard Loctite Orange in there. Btw to get that sucker off on the '85 was trippy, where I was completely unable to do it on an S4 with the intake in-place.
pps: WHat the heck is that test port up front used for? Man, what a setup!!
928 Engine Re-Re-Rebuild Specialist
I recall being able to replace mine by loosening the portion of the intake closest to the thermostat housing enough to get the housing off. One of the advantages of the massive 85-86 intake manifold I guess....separate sections!
