Silicone hose kit fitment
81' LJet, I ordered a 928 motorsports silicone kit. 10mm seems correct, I then moved on to the fuel injection vacuum hoses. The 6mm hose seems to large minimally, and the 3mm is too tight. Took a picture of the differences also, anyone else run into this? There's no further options on the 928motorsports page. The 6mm will work with a clamp and the 3mm is just much smaller and the hoses are designed that size for a reason I'm sure.
The 3mm stretches and has a nice seal on everything. The 6mm was useless to me when I got the kit years ago as well for my 81.
However silicone leaks hydrocarbons and will go soft moderately quickly.
Also, don't use the silicone hose from the brake booster to the spider body if one came with the kit. That needs to be a special non-collapsing hose or you'll lose brake assist.
RennHarry (11-18-2022)
Originally Posted by Speedtoys
Silicone hose will also dissolve from the inside out in the presence of hydrocarbons.
Really a very poor choice of automotive hose.
I have never understood the attraction of silicone vacuum hose use.
The rigid plastic lines and elbows are what you need.
Buy Roger's kit for your model year. Roger knows best.
Half of their stuff that needs modifications to work correctly once you get it, too...
You wont find silicone hoses in a -professional- shop..because chemistry.
Vacuum comes from the crankcase, car off, hydrocarbons wander...
928motorsports also sells half of their stuff that needs modifications to work correctly once you get it, too.
Just saying.
Just saying.
https://rennlist.com/forums/928-foru...l#post18471257
Or..find metric vacuum hose at the parts store..by default the will sell EVAP safe hose, but not always metric which will fit nice and proper.
If you have to have the bling, then find some FKM lined silicone hose that is safe for EVAP applications.
Administrator - "Tyson"
I use this for vaccum lines on all my cars, Roger can get it:
https://www.wurthusa.com/Service-and...ll%29/p/189502
https://www.wurthusa.com/Service-and...%29/p/18950410
You can buy metric Viton hose. That stuff will probably outlive the car and it is easy to find online.
Otherwise you can find the cloth lined factory stuff from any VW restoration shop. It was an extremely common hose during that era.
I will correct immediately next time I'm near it.
Thank you & Speedtoys for this bit of information
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
