928 Forum 1978-1995
Sponsored by: 928 Specialists
Leaking O-ring
Old Sep 27, 2022 | 04:27 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Default Leaking O-ring
This is a new one for me. Sam said he heard hissing. Passed a smoke test. But, my son wanted to apply smoke to the area where he heard hissing.
We found this:
Can't wait to find out what happened.
Old Sep 27, 2022 | 04:51 PM
FredR's Avatar
FredR
The engine is at idle and it will be pulling maximum vacuum that will be close to 20 inches Hg so you have a powerful "vacuum cleaner" sucking in the smoke.
Clearly the lower O ring on the injector is not sealing [paint missing?], the ring has failed or is simply not present. If it has the more common [smaller size] O ring typically found on injectors that will also leak profoundly
