Originally posted by heinrich Umm JE ... say ... MY rear ac makes an unusually loud SUCKING sound ... What do you think the problem could be?
Ummmmm, the rear lines sitting directly behind me keeping me company, and the non rear front lines that should be keeping you company that I can't seem to be able to remove from my freeking S4?
I have a call into DR, who may have some used ones. 928 Intl. is out of used ones. Saturday buddy. We'll have this resolved by Saturday.
Originally posted by JE928Sx4 Ummmmm, the rear lines sitting directly behind me keeping me company, and the non rear front lines that should be keeping you company that I can't seem to be able to remove from my freeking S4?
I still have your Devek radiator box to send them to you though!
Originally posted by borland Yes, even with the spring washers installed, something in the rear a/c rattles every time I hit a bump in the road; which around here, is quite often.
It sounds like the plastic diverters, but I'm not quite sure. I've taken the cover off a couple of times, but never noticed anything suspect.
Pull the topcover to make sure all the screws are in place that hold the unit in. The fan is built in with the cooling lines and is very stable. It could only be the bearings otherwise. Heinrich may have a spare rear unit. I got his lines.
