HVAC relay testing
Thanks all, I'll consider options now for repair or replacement.
In the interim is there any way (simply and practically) to rig the AC to run full time? Coming into spring here and whilst the temperatures here do not reach these extremes of some pace we have a much higher UV level and that hot sun pouring into the greenhouse that is the 928 makes it fairly uncomfortable for half of the year.
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
Bales (09-06-2022)
It looks rather better than I imagined. It seems pins 5 & slightly 6 have some extra tinning added to the edge connector. It would be good to try to get that levelled back out (its hard to tell how bad it actually is).
If needed heat it up and wipe it away off the edge to flatten & smooth it down. Extra thickness & roughness there will damage the edge connector female terminals...
Alan
Alan
It really is quite minor, this photo after a bit more clean up. I'd like to take a little more off pin 5 but there's not enough on there to cause a connector problem or damage the female side.
Use a DVM on continuity mode to verify the non visually obvious connections - but whichever of those two go back to 4 & 7 both of those are coil pins and the coil orientation doesn't matter for these relays...
Alan
Alan
Possibly - but use continuity (diode tester) not ohms mode and try with the probes reversed and try both sides of the board - make sure you are contacting bare metal (solder, clean trace).
Alan
Alan
Never used that setting before, that beep is quite handy! Unfortunately same result, good beep on 5, 6, 8, 9. Nothing on 4 & 7. Only able to test one side of the board as the holes have no trace/solder on one side.
Also test for continuity between Trace #4 and #15 (again there is a diode).
Alan
Getting nothing on 11 & 15 either.... and nothing between and 4 & 15.
While I'm here, any tips for fitting the 16awg into the holes in the pcb, it's a little large. Do I drill them out slightly or trim a few strands off the wire?
