not starting - rat-tat-tat-tat-tat.
Originally posted by Nathan Valles
I'll open this to the experts, but is there any reason not to hook up a second battery by using a set of jumper cables, same as when you need a jump. Should remove any question about battery strength and capacity by having 2 batteries hooked up to the car.
It depends. Maybe it will work, but the results of that test are not guaranteed to be conclusive. You can view the batteries as "buckets" that each contain a certain amount of energy. If one of them is too low, it will take some of what's in the other "bucket". In extreme cases, enough energy goes into the low battery that you still don't have enough energy to crank the engine. Other factors will affect your results, such as the wire gauge of the cables, the resistance in the connections to the batteries and between the cables & cable clamps... If the battery that's in the car is not holding a charge, or has insufficient output you're better off swapping in the "good" battery. That way you are reducing the number of unknowns, rather than adding to them.
5th Gear
well the 48-hour slow charge did the trick!
got the car home from stowage
also noticed some paperwork in the glovebox a bit damp - maybe that affected things too with the garage conditions.
_av
928s
_av
928s
