Declassifying the B-2 _ _ _ _ _ _ _ _ _.
Has anyone out there,anywhere, repaired their own 4 speed automatic transmission?! My B2 brake band piston is destroyed. That's all!! I do not need a new/rebuilt transmission. What I need to know from the intelligentsia, is the improved version part#. I've asked the B3 and not 1 of them knows anything. Not even the 1or 2 that rebuilds them. Hope I don't have to do some cast iron welding. Must be classified!!!!!!!!! I know ,I know if you tell me then ,you'll have to kill me! I'll be hiding under the car where the transmission is supposed to be. Thankyou. Mike
The B-3 doesn't rebuild them. They send all that stuff out. Call a good local Mercedes shop and I bet they have repaired in house more than the B-3 have sold altogether!!! The transmission is pretty straightforward actually. Did your shift band just break or did is shatter with little parts and pieces everywhere.....?
Check out www.mercedesshop.com - go to the forum, and post asking about it. I believe I have read about B2 piston failures, and the fix. DO a search on B2 specifically....
jp 83 Euro S AT 47k Whiteout.
You could have changed the servo with the trans. in the car; clean the servo bore with red scotch bright. You should also change the front seal and torque converter flange bearings.
005 997 70 48 B2 seal ring
107 270 04 32 updated B2 piston
126 277 08 50 plastic bushing for updated B2 piston
006 997 73 47 seal that holds in the bushing
Steves right. If it is just the servo-piston, it can be done easily in the car. If you take the trans down, do all the outer seals since they tend to leak an only cost about $50 for everything. Best of luck.
Yes ,I did realize that I didn't have to take the tranny out to remove the B2 piston but my curiosity got the better of me. I hate just scratching the surface. Anyway, converter seals have been weeping for quite some time and I'm getting a little clunk and funk in the L.S.D. It was quite dirty under there and I hate it, I hate it ,I hate it! Scott ,hi there .Iwill post some pics. as soon as I figure out how? To all that have replied THANK-YOU, Dont stop the info. Mike
