Thermostat Housing
Thermostat Housing
Hi, I have removed the T/ Housing to replace all of the seals / thermostat etc. Does anybody recommend / know of any additional sealant or stuff that can be used to help prevent seepage when it is all put back together?
The trick is to get the surfaces clean. Then don't use anything and it'll be fine.
If the surfaces are corroded then I'll employ a thin coat of hardening gasket maker. (Like permatex "#1") That will be hard to get off next time.
