upgrade transmissions ?
Just curious as I saw it mentioned in another post. I have a 81 with a 3 speed tranny. What would be involved to make it a 4 speed auto ? Is it just a bolt on replacement ?
It's not so easy swap as it seems. 4sp autobox is larger than 3sp. So much so that later bodies have larger space for it. It will not fit without some modifications between rear seats. Certainly doable but not direct bolt on job.
Erkka
1992 928 GTS 5-speed large body
Oak Green Metallic 22L
Classic Gray MX
Erkka
Classic Gray MX
Originally posted by Jim bailey - 928 International
but the conversion from 3 spd to 4 speed at smokes the tires . Wayne is very serious about increasing performance !
https://rennlist.com/forums/showthre...5&pagenumber=2
Wayne "With the side pipes" did the conversion ! ! !
I did this to my old 81. You'll need a newer style TT, the cross brace should be fine, but you'll need the downshift cable or "bowden" cable from a later car.
It was a great change while it lasted. Woke the car up considerably. I wish I still had that car. I'd do it again.
