1989 Hood Won't Latch
Make sure the release cable isn't too tight. Also, check the condition of the spring on the latch mechanism (visible from underside). If neither of those are your culprit, then it comes down to striker alignment. Either a misaligned hood or and/or a poorly adjusted striker is at fault.
