JT gets a GT – a rookie R&R
Congratulations!
What a great car to save! There is just something about the way the GT's rev that gives them an edge over nearly all other 928's.
Enjoy and get rid of those rub strips when you repaint...
JBT3 (05-30-2022)
So I dug into the audio a bit to see what I’m dealing with here. Looks like the decision for stock vs. aftermarket has already been made for me.
Stock amp is still in place, but not sure if I’ll keep it or replace. Since I’m updating every other component, I’ll probably update this one as well.
Amateur crimping going on there. The kind I did in high school. Hmmm…. This is all lower priority to mechanical and electrical, but was curious what I had as a starting point.
Glad I did look around now, because I found this jumped connector. What should this connect into? (1990 GT) Thanks
Congratulations! The 90/91GT is probably the pinnacle of the line. You've got a lot of work ahead to really get it humming but it is a great car.
Some of your items are not like the others. Your hatch problem might just be the plastic spacer on the lower bracket, $40 and 1 minute to fix (newbie check: you know the "button" is pulled not pressed, right?).
Intake refresh is a pretty big deal, with about $2K of parts and multiple vendors involved. It is an extremely rewarding exercise and it was the first big job I did myself. It results in practically a new engine. Worf928 has an excellent writeup that is online somewhere and I followed it to the letter. The subject car was a 90GT. Dwayne's Garage has another one for an '87 S4. Plan to replace the fuel lines, thermostat, and oil filler neck, rebuild the MAF, and replace all parts and hoses under the intake with new. There are refresh kits from the major 928 specialist vendors.
On this car more than others, routing the hoses and even orienting the clamps is challenging, so take a lot of pics whenever disassembling anything.
Personal opinion: Audio is very important and the OEM stuff is not up to snuff. I recommend to rip and replace everything unless it's already very good aftermarket. A stock aficionado will pay a lot for that ancient technology amp, head unit, speakers, and maybe even crossovers, and you will have better sound and a profit.
Wow. What a car.
And what a list! Way outside my comfort level to DIY, but you can save a boatload doing it all.
Following.
Cheers
Following.
Cheers
Today I dove into the PSD. It didn’t take long to find the problem.
Reservoir was bone dry. Filled it up with new brake fluid and starting bleeding the system per this excellent write up: http://www.928intl.com/repair/psd1.pdf
Got lots of foam at first, but soon the brake fluid started flowing through. Hardest part of the procedure was getting a 7mm on the bleed valve for the PSD slave cylinder. Got foam there too until the new fluid flowed through. I didn’t get a chance to test drive it afterwards, but hopefully tomorrow.
RennHarry (06-11-2022)
If you need me, I’ll be in the garage!
The following 4 users liked this post by JBT3:
928NOOBIE (06-11-2022),
Bertrand Daoust (06-11-2022),
Gary Knox (06-11-2022),
JBT3, that looks like 928 Christmas!
Cheers
Cheers
Got some quality garage time on Saturday and took the shields off to have a good look around. Also first time I jacked up the entire car to take a good look around. Went ahead and did oil and filter and then changed the diff oil. Happy to report not too many new issues found. Shields had collection of OEM and non-oem bolts. (No surprise). Exhaust is in much better shape than I thought save the lack of a muffler. I’m shopping around for either a used OEM or aftermarket. Haven’t decided.
Two new issues found were a coolant leak from the pressure switch 928.641.513.00 (appears to be a common failure point based on the threads I saw) and I found the alternator cooling hose 928.603.143.04 was chewed to bits. Someone had just stuffed the remnants into the cooling duct. Seriously doubt much air was getting through there.
Will get parts ordered to fix both of those issues. Both look easy.
RennHarry (06-12-2022)
Former Vendor
Got it. Adding fuel lines and Petza’s suggested lines to the list. I need to research those to see when I can work them into the plan.
You’ll notice the extra wire near the PSD. It appears to be an attempt to ground. It disappears into the light on the left rear bumper. Looks like an attempt by someone to bandaid an issue. I’ll get to that later.
Also wanted to show y’all a picture of my “custom” exhaust.
Look Ma, no muffler! It just pipe from the small silencers. Notice the nice rust holes in the pipe. The word “janky” comes to mind. I will replace / update.
Loss of fluid means only one thing...there's a leak.
The most common leak is the slave cylinder on the side of the transmission.
The second most common leak is the flexible hose to the transmission.
The other thing which occurs, commonly, is that the pressure accumulator splits at the friction weld and sprays out fluid at high pressures.
RennHarry (06-13-2022)
Keep in mind that brake fluid, in the PSD system, does not evaporate.
On the bright side you have Louie Ott rear rear drop links (red)
Louie Ott rear drop links - red on the left side of the picture.
Former Vendor
This "weep hole" is directly under the center of the slave, close to the mounting flange.
Catching up on a few replies.
Unfortunately, it looks like the hatch is not just the plastic spacer. The motor will run with I pull up the release ***** and I can see an output shaft turning, but the vertical bar isn't moving at all. So either it isn't in contact or something is stripped. It's not urgent, so I'll live with it for now. I have bigger fish to fry at this point.
Not sure I've seen Dave's write up on the intake refresh, but I have studied Dwayne's. If anyone has a link to Dave's (@worf928) please let me know. I searched, but didn't find it.
I'll be taking it slow and probably asking lots of rookie type questions along the way, but I enjoy getting to know the car this way. It's also a bit like therapy.
Costs a lot more than we normally spend on Christmas! But will be worth it.
Thanks again, Greg! I will start to research the slave cylinder and see if it can be rebuilt or if I just need to replace. Will come back if I can't find answers.
Thanks! I wasn't really looking for one to save. Got carried away in the auction, but it's mine now and I'm happy to save one, especially a GT. Looking forward to the day when I can drive it like Dr. Porsche intended.
There's a vent hole drilled into the slave cylinder, so if it leaks brake fluid past the internal seals, the fluid can escape and not be forced past the rubber bellows inside the transmission.
