1985 Brake Upgrade...?
You need a set of caliper adapters along with a set of the early spindles (78-81) to make it work.
Easiest and most effective upgrade you can do would to be to get a set of better pads.
There was a user @xschop who used to make caliper adapters for the S spindle but he hasn't been active in a while.
davek9 (05-09-2022)
They eat iron, and that will corrode into wheel and body paint.
It fits with the normal adapter for the 78-81 as the caliper bolt spacing is the same, but the holes are 4mm back compared to where they need to be so it wont clear the 993 rotor.
The Perfex adapter accounts for this as it was made with the Cayenne rotors in mind (the D2s have the same offset as the S4, GTS, etc.) so it will fit.
The D2 also bolts up to the factory S4 hub, but you need 350mm rotors with a S4 rotor offset to make it work so there is no cheap off the shelf rotor option.
For reference, the depth on a Cayenne rotor is 69mm hat to back of rotor face, a 993 is 73, and the S4/GTS is 77.
You also need a set of longer caliper bolts. Panamera Part #999 067 040 01 works perfectly for this.
Also, shout out and thank you to @Jerry Feather for the hubcentric rings, they fit perfectly after a touch of sanding.
There will be a large "wasted" area of the rotor, inboard of the brake pads.
Additionally, there will be no additional brake pad to reduce the amount of friction per square inch.
For "street car" occasional panic stopping/stop light stopping, this conversion will definitely help.
For continuous brake use (any track/canyon carving use), this conversion will simply "cook" the stock pads (and allow brake fade/boiling brake fluid) even quicker.
S4 upper and lower contol arms, ball joints, and spindles, plus S4 calipers and rotors..
928 International generally has these pieces, although they are likely going to need some "refreshing".
Rear S4 calipers bolt directly on.
Booster and master will work, if in good condition.
If anyone is looking to go this path, I have a deal on the brake parts..
https://rennlist.com/forums/for-sale...l#post18195000
