928 Forum 1978-1995
Sponsored by: 928 Specialists
Strange electrical gremlin
Old 04-23-2023, 09:18 PM
Periokid
Periokid's Avatar
Originally Posted by John S. Markowitz
THIS...
Seems counter-intuitive but this was absolutely the problem when I had all of these weird issues at once.
John,
I don't understand your statement. THIS what? I checked the x bus power and it is good. Where do I go next?
Old 04-24-2023, 11:56 AM
Alan
Electron Wrangler
Alan's Avatar
I'm on a cruise in for the next 10 days so won't be able to assist you till after then.
Alan
The following 2 users liked this post by Alan:
Mrmerlin (04-24-2023), RennHarry (04-24-2023)
Old 04-24-2023, 02:04 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,437 Likes on 1,366 Posts
Alan, I hope you Enjoy your cruise !
Thanks for everything you do here, your talents are much appreciated.
The following 2 users liked this post by Mrmerlin:
Bertrand Daoust (04-25-2023), RennHarry (04-24-2023)
Old 04-24-2023, 11:08 PM
Periokid
Periokid's Avatar
Thank you Alan. Have a great trip. I am looking forward to hearing from you.
Of course, I am open to any suggestions from anyone else too.
Old 05-12-2023, 10:52 PM
Periokid
Periokid's Avatar
@Alan
I hope you had a great trip. Let me know if you have any ideas to move forward. Thanks.
Old 06-11-2023, 04:16 PM
Periokid
Periokid's Avatar
So I still have this problem with no solution. I removed the fuse box today. I cleaned all contacts. I was looking at the back of the panel and was curious about something. Some fuses have a wire going to one side of the fuse but not the other. I assumed that a fuse needs a connection on both sides. Seems logical. But if you look at the photo I took, fuse number 3 is empty on both top and bottom, as I would expect since that is not used. #4 is the brake lights and only has a connection on the bottom. I can't find any disconnected wires. This is not the only fuse to have this appearance. I added numbers to ID the fuse locations since it is backwards.
Old 06-11-2023, 06:12 PM
Alan
Electron Wrangler
Alan's Avatar
Read this to understand: Fuse panel modification
Alan
Old 06-11-2023, 06:29 PM
Periokid
Periokid's Avatar
So this statement is what you are referring to:
"IMPORTANT !!! You do know that some of the fuse inputs (top connections) are shorted together inside the fuse blocks?? (this varies by year) you need to disassemble these and swap the bus bars for all fuses you need to be separate... THIS IS REALLY REALLY IMPORTANT!!! you can test with a multimeter - not all blocks have this, but all panels have at least some blocks like this...."
Makes sense. Now I'll put the fuse box back in the car. Cross your fingers.
Old 06-11-2023, 07:07 PM
Periokid
Periokid's Avatar
Alan,
While I have your attention, before I put this fuse panel back....
What do the brake lights, power windows, sunroof and headlight motors have in common?
Maybe the ignition switch is next to look at?
Old 06-11-2023, 07:51 PM
Alan
Electron Wrangler
Alan's Avatar
See the pictures later in the thread to understand how this works.
The brake lights, headlight motor, wipers, cruise control, power outlet, windows and sunroof are all controlled by the X-bus - The "X" output of the ignition switch. You said you tested it - but try testing it while activating one of those - say the brakes, it may seem to work (voltage present) when there is no current consumption and fail (voltage drops close to 0v) when there is demand.
19 posts ago I suggested it was the ignition switch - nothing has really changed... I think you need to dig in.
Alan
Quick Reply: Strange electrical gremlin
