Hi Dave great instructions with pictures.. if you want you can add to your site that torq for the following tie rod to steering arm is 47 ftlb and your
tie rod to steering rack is 108 ftlb ...Dave...
928 Engine Re-Re-Rebuild Specialist Rennlist Member
I just noticed this: if you look closely at the picture I've got on top of this page, you can see my Ott x-over cat bypass and its side-mounted O2 sensor.
How come you didn't explain to the crowd our first method of tie rod end removal? You know, when we hit the threaded part with the sledge on the 81? Oh yeah, that would pretty much sum up the WHOLE dismantling project.
WARNING dont follow those instructions about using the pipe wrench,
you need the 32mm and a 22mm wrench set, push the bumper stop inwards to the rack body then fit the 22mm to the rack rod..
Counter hold the rack while squeezing the bigger wrench towards it, wear gloves
If you use the pipe wrench you can possibly nick the shaft this will in short order cut the ends of the rack seals and the boots will fill with oil and the rack will have to be replaced
