I have an S4 intake that I was going to powder coat, didn't do it. Ott drop links?, [edit: drop links are spoken for] some other parts I will list and pics later if any interest.
I bought these many years ago for an S3 and kept them. They do have some identifying marks: "ALINABAL USA" stamped across the top and "VM-8" stamped at the 6 o'clock position. If you search there are several threads on "Ott Drop Links" from 2014. I believe these fit the rear. Apparently there were some brackets to bolt in for altering the position/angle of installation; I don't know if the brackets were part of the original package. I do not have those. All 4 of the bushings move freely within the "heads". They retailed for $250/pair, I am seeking $150 for the pair. Why they included only 2 socket head bolts and 8 washers I do not know. What you see is what you get.
Reason: Adding
495 hp LS or 750 hp Mercury Marine DOHC. Get "Porsche" engraved on the cam covers of the DOHC LS and nobody will know the difference (I will sweep up all the little bits of transmission when you are done.)
