928 Forum 1978-1995
Sponsored by: 928 Specialists
TB cable
Old Jan 1, 2022 | 11:34 AM
DHS928's Avatar
DHS928
Default TB cable
Got this far, I can not get the cable to the TB off, I do not see any clip does it just pop off? Have really tugged on it but no luck.
The cable hooked on the arm.
Old Jan 1, 2022 | 11:42 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
spray PB into the ball socket,
repeat a few times for a few hours,
wait a few hours then try the removal with a pair of side cutters.
NOTE the metal locking wire is corroded and has the have the corrosion removed,
the PB will do this just takes a few hours
Old Jan 1, 2022 | 01:58 PM
StratfordShark's Avatar
StratfordShark
A 10mm wrench is just right for prising off those cable ball joints. After waiting for penetrant to take effect just prise from under the socket end.
Old Jan 1, 2022 | 02:04 PM
DHS928's Avatar
DHS928
Done, PB Blaster and a lot of effort!
Old Jan 1, 2022 | 03:18 PM
DHS928's Avatar
DHS928
So I have 9 washers and ten spacers! Was the rear left one had that air box brace not have a washer? Looked in all the intakes no washer, have all eight plugged.
Just 9 washers?
Old Jan 1, 2022 | 11:46 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
No, there should be 10.
(There's nothing to crush the rubber grommet, if the washer is missing.)
