928 Forum 1978-1995
Sponsored by: 928 Specialists
SC Install Update
Old 04-21-2004 | 09:36 AM
Scott MacDonald's Avatar
Scott MacDonald
Bill,
Will the car be ready for the Musante Motorsports Dyno day this Saturday (4/24)? Would love to see the dyno numbers!!!
Scott
Old 04-21-2004 | 09:48 AM
bshaw's Avatar
bshaw
I'm still waiting for parts. If they make it in the next couple of days there is still a chance I'll be there.
Old 04-21-2004 | 10:34 AM
Eric Dvorak's Avatar
Eric Dvorak
Bill, I was wondering, how do you get the Cyclone ECU to work on the V8, isn't the Cyclone a V6? (firing 8 injectors insted of 6)
Good to see everything is going well.
Old 04-21-2004 | 11:08 AM
bshaw's Avatar
bshaw
Yes, the Syclone is a V6, but the 749 has a cylinder select byte allowing 4, 6, or 8 cylinder operation.
Old 04-21-2004 | 11:13 AM
Eric Dvorak
Ahhh, that explains it. I may have to source one of those to play with.
Old 04-21-2004 | 11:30 AM
Lagavulin's Avatar
Lagavulin
This ECU sounds very interesting; can you provide a link for more information?
Do you know what the max MAF voltage, or max boost, the ECU can recognize?
Most importantly, are you able to alter the fuel tables?
Old 04-21-2004 | 11:47 AM
bshaw's Avatar
bshaw
There's a ton of info on the diy-efi web site... http://www.diy-efi.org/gmecm/ecm_info/1227749/
No MAF, it's a MAP system. Stock it's set up for a 2 bar MAP sensor. The Syclone guys have modified it for a 3 bar MAP sensor. Tables are fully editable and there are numerous graphical editors for the calibration parameters. I'm using TunerCat (http://www.tunercat.com) and Promgrammer (available at the SyTy web site) for altering the calibration parameters, and DataMaster for logging data. The code has been disassembled and commented listings are available if you need that level of detail.
Old 04-21-2004 | 12:04 PM
BrianG's Avatar
BrianG
http://mywebpages.comcast.net/p-928/749.html.
Can't get this page to open.......
Old 04-21-2004 | 02:39 PM
Andrew Schauer's Avatar
Andrew Schauer
Remove the "." (period) at the end of the link, and it should work fine. I had the same problem.
Andrew Schauer
1980 5-speed
Quick Reply: SC Install Update
