928 Forum 1978-1995
Sponsored by: 928 Specialists
Front bumper removal 87 S4
Old Dec 19, 2021 | 12:13 PM
DHS928's Avatar
DHS928
Question Front bumper removal 87 S4
OK I did try a search, going to do the top refresh and would like to pull the front bumper cover, the PO had sanded it down but never got to paint it. (He died!) so I just saw that it really needs to be shell blasted then painted. I saw a write up for pulling the front cover of but can not find it.
thanks
Dan
Old Dec 19, 2021 | 12:39 PM
Bertrand Daoust's Avatar
Bertrand Daoust
Here's one:
1987 FRONT BUMPER COVER REPLACEMENT PROCEDURE w/PICs - Rennlist - Porsche Discussion Forums
Old Dec 19, 2021 | 01:08 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
while you have the PU cover off,
measure the shocks for the bumper bar ,
you need them to be 70 mm in undamaged condition
Old Dec 19, 2021 | 01:22 PM
Pete in DC's Avatar
Pete in DC
Wow. @Dwayne 's 11-year-old, "newbie-rated" writeup is awesome for 2021 newbies. Thanks to him and @Bertrand Daoust for the resurrection.
Old Dec 19, 2021 | 07:09 PM
DHS928's Avatar
DHS928
Just got it off, not to hard, two really rusty nuts. Will get all the lights out and get it walnut shell blasted so it can be painted. Will start on the intake refresh and FI harness. Nice winter project.
Old Dec 26, 2021 | 12:40 PM
DHS928's Avatar
DHS928
yes it looks like both are at 70mm’s
Old Dec 26, 2021 | 12:57 PM
Michael Benno's Avatar
Michael Benno
With the cover off you may want to take the opportunity to chase the threads on all the M6 mounting bolts. Cleaning off the rust and getting a good clean thread will be helpful and reassembly.
Also note the mounting clips at the bottom are riveted and some of those rivets may have come free or the clips may be broken it would be a good opportunity to drill and replace broken rivets/clips. Simple aluminum rivets will suffice
Another thing you could consider is deleting the factory headlight washers if you want to. Porsche made a headlight washer delete cap for the 944 which is a direct screw in perfect fit for the holes in the bumper.
Porsche 944 944 S2 Headlight Washer Blind Cap 95162830100. The Cap primed but you can sand off the primer and polish so it looks black or paint it to match your car
