928 Forum 1978-1995
Sponsored by: 928 Specialists
Titanium exhaust stud kit for Porsche 928
Old 12-12-2021, 12:09 AM
Silverlake
Former Vendor
Silverlake's Avatar
Default Titanium exhaust stud kit for Porsche 928
We now offer a titanium exhaust stud kit for Porsche 928 and 968Our set is the perfect solution to future proof your exhaust manifold to cylinder head. Our titanium alloy studs will not rust after repeated heat cycles, and will be easily removed when needed
The stud - made in Japan to exact Silverlake specifications, the titanium alloy studs will not rust after repeated heat cycles, hence will be easily removed when needed. Ti6Al4V alloy is as strong as steel but 45% lighter.
The nut - originally designed for the aerospace industry, k-nuts are the most applied locking nuts in high-end motorsports applications, due to their strength, low weight and temperature and vibration resistance. These European made all-metal nuts will lock once torqued up and will never unscrew unless desired.
The washer - made in the USA to exact Silverlake specifications, the copper washer will not corrode nor bond to the titanium stud or the aerospace steel nut, making future removal easier. These corrosion-resistant washers will compress for a tight fit and further reduce the chance of unscrewing.
Here some pics of the kit, and the studs installed on a 997 GT3.
The following 5 users liked this post by Silverlake:
85euro928 (12-12-2021), AA996 (12-12-2021), drkekar (12-12-2021), monkez (12-12-2021), Mrmerlin (12-12-2021)
Old 12-12-2021, 10:04 AM
slownrusty
slownrusty's Avatar
Nice!
Weren't you guys featured on Speedhunters?
Old 12-12-2021, 02:11 PM
Silverlake
Former Vendor
Silverlake's Avatar
Hi! I don't think so, that would have been nice!
Old 12-14-2021, 01:36 PM
hwyengr
hwyengr's Avatar
If you guys are in the custom stud/bolt business, any chance we could request a run of the impossible-to-find 85/early-86 one-piece cam cover bolts?
Also, howdy neighbor! I used to live in Silver Lake, around the corner from Tacos Delta.
Old 12-14-2021, 05:12 PM
GregBBRD
Former Vendor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
Very nice looking hardware!
Old 12-14-2021, 08:34 PM
Silverlake
Former Vendor
Silverlake's Avatar
Thanks!
Old 12-14-2021, 09:54 PM
GregBBRD
Former Vendor
GregBBRD's Avatar
Originally Posted by Silverlake
Thanks!
Since you are a sponsor, I think you can post a price here, too!
hacker-pschorr (12-15-2021)
Old 12-15-2021, 12:08 AM
Silverlake
Former Vendor
Silverlake's Avatar
Hi,
Could you please share a pic?
Old 12-15-2021, 12:10 AM
Silverlake
Former Vendor
Silverlake's Avatar
Greg,
Price is $209.
https://www.silverlakeprojects.com/c...e-928-products
Silverlake
Former Vendor
Silverlake's Avatar
Jeremy,
Could you please share a pic of that bolt?
Thanks,
Carlos
Old 12-15-2021, 12:56 AM
hwyengr
hwyengr's Avatar
Jeremy,
Thanks,
Carlos
Looks like the long bolt is still available from Porsche, but runs $35 per and 18 are needed. There are also 6 short bolts which are long NLA. If this is a possibility, I'll try to find someone with an 86.5 who could take measurements.
Old 12-15-2021, 01:44 AM
GregBBRD
Former Vendor
GregBBRD's Avatar
78-86 heads require 16 studs....and these days,, we see are seeing a fair amount of these which have broken off, in the head.
87-95 heads require 24 studs. Not as prone to failure...at least not on this coast.
All models use the 8 x 30 stud.
$209 is for which years? (I don't see any differentiation in your web site.)
BTW, a factory stud is now over $4.00, so you are providing a nice option, for a fairly reasonable price.
I use shorter studs with my inconel and stainless header flanges for 928's. If you also offer shorter studs, what lengths do you have?
Old 12-15-2021, 01:49 AM
Silverlake
Former Vendor
Silverlake's Avatar
Hi Greg,
$209 is for all 16 exhaust stud, nuts, and washers; for all years.
Inconel suds are 40mm long, they are shorter and meant to be for some 911 models, but will likely work with our nut on 928s...
Carlos
Old 12-15-2021, 04:40 AM
Cortina
Cortina's Avatar
Hi Greg,
Carlos
Do you mean for all years that only need 16 studs ??? (Or did you not read above !)
Old 12-15-2021, 03:55 PM
davek9
davek9's Avatar
87 to 95 have three studs per exhaust port.
78-86 only have two studs per port, on both 16 and 32 valve engines.
Dave K
Quick Reply: Titanium exhaust stud kit for Porsche 928
