New Motor Seized
New Motor Seized
I just installed a new motor in my 85 8v and after running for less than 3 seconds the motor has locked up. Does not turn over at all even with spark plugs removed. The timing belt is fine and the engine has oil. The engine used to turn by hand before it seized. Any ideas on what could've caused it to seize? Do I probably need a new motor?
Welcome! What is the model/year of your Porsche?
Edit: Is it a 1985 928?
Former Vendor
3 seconds?
That's an incredibly short period of time!
It takes more than 3 seconds for oil to reach the heads, but regardless of that, an engine will run for more than 3 seconds, without any oil!
More details needed.
What is the history of the engine?
Why did you replace the original engine?
Ducman82 (12-07-2021)
The following 2 users liked this post by Mark Anderson:
928 DesMoines (12-04-2021),
Mrmerlin (12-03-2021)
Did the engine spin before you put it in?
Always first try to spin the engine by hand to see whether there are no obstructions. Afterwards you can do a real start.
I did this with my engine (16v 4.7 300hp) to make sure timing and belt is properly set.
Questions:
When you built the engine, what did you change?
Pistons?
Piston ring gap?
Did you prime oil before you started?
Can you spin it backwards? ( slow by hand )
3 sec sounds like a shim or object inside the engine.
Pistons?
Piston ring gap?
Former Vendor
The OP seems to have posted and then just disappeared.
Another 928 destined to be parted out?
Another 928 mysteriously catches on fire?
Suicide Help Line intervened with a 5150 hold?
bureau13 (12-12-2021)
