Idle issue when car warms up 89 S4 Auto
![order](https://rennlist.com/forums/graemlins/order.gif)
When car is cold I can start it and drive like before no issue, strong (keep in mind it was 40 F deg. outside today) I was able to drive it about 4 miles and than it states idling. Is it possible that it could run on all cylinders and only half when it warms up ? don’t think so, it does feel like a vacuum leak (had a 79 had the same issue, sold it as I had put too much $ in it and issue still existed) - no one in my area to really help with 928s most mechanics afraid of them.
Team Owner
probably moved the coil wire and its loose or touching some part of its run,
NOTE coil wire should not touch anything, and the ends should be clean.
use a IR gun to test what cylinders are hot then swap the coil wires see if the cylinders change.
You might need a new coil wire.
Check the wires going to the oil pressure sender,
and at the 14 pin connector spray deoxit 100 on the pins inspect the wires for shedding insulation
^^ I had an ignition amp fail intermittently when warm in my 89 so it can definitely idle fine when cold and then lose half of the cylinders after warming up for a bit.
But I would do what Stan is suggesting and check you coils wires and connections first.
