WTB- small plastic washers for lens crew
11-17-2021, 10:14 PM
Guys
Does anyone have a source for the plastic washers on rear lens screw
see photo
11-17-2021, 10:25 PM
Archive GatekeeperRennlist Member
I've never seen the nylon washers called out separately in PET but I bet that there's a pretty good match somewhere on this page at McMaster:
https://www.mcmaster.com/washers/met...astic-washers/
11-18-2021, 09:29 AM
Plastic washer
Thanks for reply ….
I have bought so many items from McMaster , bolts,nuts, fuel vent hoses etc.
Should have know
Regards
Frank
11-18-2021, 10:57 AM
My local Ace hardware has a surprisingly wide variety of fasteners incl. these washers in nylon and poly ethylene
11-18-2021, 09:06 PM
Guys
Thanks did find on McMaster site …
There were only 2 possible versions ( both were 8mm OD)
Hope the 3.2ID vs the 3.7ID slides over screw
Regards
Frank
11-21-2021, 09:58 AM
Check with Airparts in Kansas. Or even Aircraft Spruce.
11-21-2021, 10:20 AM
Jerry
So I received the 3.2mm and it’s to tight so ordered the 3.7mm .
Will see….should fit better
Otherwise will try Airparts
Frank
