928 1983 S - Euro - Door Lock Fix
Hi everyone,
I can only open the passenger door if i turn the key to unlock and pull on the handle. The pop up lock indicator is permanently half way down.
Any ideas for a fix.
does pass. lock motor run when using key in drivers door? - does it run when using key in pass door? - does **** inside unlock it? - if i recall there are 2 fuses in separate holders for the lock motors on top of the CE panel
Team Owner
from the report it sounds like the linkage has come loose from the latch arm its held in with small clips PN 993 531 563 00
read this for pictures
Door lock locks when the inside handle is pulled
Team Owner
yes and yes
Team Owner
search here on RL for door panel removal tips and tricks
